Posted December 19, 201015 yr hey guys im kinda new to wiring subwoofers so i need some help. i hear now a days people are using these speaker pins and banana plugs to wire up there subwoofers, how do you use both of them? and which one is the better to use? one more thing, what gauge wire would u use to wire 2 18" fi btl's? thanx Edited December 19, 201015 yr by pitbull
December 19, 201015 yr I would think it would be better to just stick he wire in there.My reasoning is the pin, since the pin is hard it would only make contact on the terminal on a very small portion. I would think you would have more actual contact between the wire and terminal as the wire would compress as the terminal releases.
December 19, 201015 yr Those banana plugs and speaker pins are almost excusively used in home audio. A striped wire and a twist conection is all you need
December 19, 201015 yr Like the others said, just strip the ends of the wire and put that in the terminals, It will have more contact area with the terminals.
December 19, 201015 yr i was wondering the same thing. glad i saw this. what gauge speaker wire though? i have some 12 gauge but i cant get 2 wires into the terminal
December 19, 201015 yr i was wondering the same thing. glad i saw this. what gauge speaker wire though? i have some 12 gauge but i cant get 2 wires into the terminalKeep the 12ga and trim a little off each until they fit.
