Posted December 24, 201015 yr I am stumped on this and it may just be something simple. Alright I am running an MS8 to (2) kicker IX 500.4s. Each amp is bridged for the front stage (one amp for horns, the other for mids). For some reason only the right side gets signal. I can mess around and get both sides to play by mixing the RCAs around. I am using RCA splitters on each channel from the MS8 to go into all the RCA inputs on the amplifiers. I'm lost
December 25, 201015 yr If the left side isn't playing, and you just switch the RCA cables at the input of the MS-8 (i.e. plug the "left" RCA into the "right" input and "right" RCA cable into the "left" input), does the left side begin to play?If so, sounds like you simply have a bad RCA cable.
December 25, 201015 yr when u are splitting the rcas... there will now be 2 lefts and 2 rights.Are you making sure u are only plugging in 1 left and 1 right from EACH split or are u running the entire split to each amp? If you are doing the last thing, that can cause a problem.
