Posted December 24, 201014 yr Which one do you guys recommend for utilizing in an enclosure to fasten the subs? Also a bolt to match with them???Going in .75" MDFhttp://www.parts-express.com/pe/showdetl.cfm?Partnumber=081-1084http://www.parts-express.com/pe/showdetl.cfm?Partnumber=081-1082 Edited December 24, 201014 yr by blunt
December 25, 201014 yr Author I was reading around and saw that people recommended using hurricane nuts to bolt the subs in to prevent screws from stripping out of the mdf.
December 25, 201014 yr I was reading around and saw that people recommended using hurricane nuts to bolt the subs in to prevent screws from stripping out of the mdf.Do you plan on taking the woofers in and out alot?
December 25, 201014 yr Author I was reading around and saw that people recommended using hurricane nuts to bolt the subs in to prevent screws from stripping out of the mdf.Do you plan on taking the woofers in and out alot?not really. what kind of screws do you recommend?
December 25, 201014 yr I was reading around and saw that people recommended using hurricane nuts to bolt the subs in to prevent screws from stripping out of the mdf.Do you plan on taking the woofers in and out alot?not really. what kind of screws do you recommend?I just use screws 1.5" long to make it through all the wood.
December 25, 201014 yr would an inch work fine? since I have the .75" mdf and then the sub?What kind of subs are you using?
December 25, 201014 yr I would get these. 3/4-1in should be fine. Pre-drill your holes first.https://www.madisound.com/store/index.php?cPath=404_18
December 26, 201014 yr Author would an inch work fine? since I have the .75" mdf and then the sub?What kind of subs are you using?FI SSD 12s
December 27, 201014 yr would an inch work fine? since I have the .75" mdf and then the sub?What kind of subs are you using?FI SSD 12sScrews will be fine.
