Posted January 3, 201114 yr I have built 2 boxes for these things and both have sounded like trash. I know they require about .6 cubes but I have yet to find the port area that is needed. I used winisd for both boxes and I have an insainamount of port noise the last box has a port 3.25x8.5x39 and I think the port length is to long already and I didn't have enough room for a larger port due to it getting longer. What size box and port should I go with?
January 3, 201114 yr i use 14-16 sq in / cube and i dont get much noise. i have one box thats 1 cube and 12 inches of port and dont get much noise either. maybe your box is leaking?
January 3, 201114 yr Author I know it's not leaking I am beginning to wonder if it is actually the location it is a console box in my Yukon in-between the middle row seats but I don't think that would cause the port noise. I am about to say forget the console box because the 10 I had built a box for did the same thing.
January 3, 201114 yr I know it's not leaking I am beginning to wonder if it is actually the location it is a console box in my Yukon in-between the middle row seats but I don't think that would cause the port noise. I am about to say forget the console box because the 10 I had built a box for did the same thing.Port down firing? Near ground or against side of seat?
January 3, 201114 yr Do you have 45's in the corners of the port? That's just a small thing that could help a bit.
January 3, 201114 yr Author Figured out what the problem is, i put the box in the cargo area and then it started pounding with no port noise. I guess I was getting some cancelation in-between the seats
