Posted January 12, 201115 yr i have a sae 1200d v.2 sundown amp going to a fi bl 10.any help would be great! im looking into this amp power kit....http://www.knukonceptz.com/productDetail.cfm?prodID=KFX-PK0is this a good deal? or should i look into a different way of everything? i dont need the (dual amp kit do i??)THANKS!!
January 12, 201115 yr Author thanks! whats the best way to figure out how much wire you need? string?? like just map out where you will run the wire?
January 12, 201115 yr That should work, but i recommend buying a lil more than you need just for running into unforeseen obstacles, Example: having to run wire on opposite side of the battery in the engine bay etc. Better to have more than not enough.
