Thread should be closed. No need to bring it up :shrug:
Indeed, especially with a dipshit post like this:
I'm not comfortable with the idea of bouncing my KIA off the rev limiter.. I love my KIA.
Since it is hardly about Fi and that was resolved, I moved this to the general subwoofer section.
  • Replies 153
  • Views 26.5k
  • Don't see why you'd expect a company to fix your screw up just because you've spent "plenty of $ " with them. If you cooked the coil, you cooked the coil. And that coil is cooked, whether you did it
  • Any update on this? If it's not going to be covered or anything I'd like to go ahead and pay and get it shipped out.... I'm having to push everything back now since my equipment failure. Thanks!
  • Seeing as how the coil looks..I would put money on your amplifier is in the process of dieing..and/or has already died and taken out a sub with it. That coil has been HOT. Not so hot that it has been
For what it's worth..that has to deal with the inductive heating of the cheap ass amps that have no filtering on the output stage of the operating frequency of the fets...
It does inductively heat the tinsel leads..and it does make them glow.
hence: rev limiter analogy, not exactly dipshitesque.
7 months later and not on topic, but referencing only the last post in a method that isn't coherent to the flow of the thread (nor my memory) is where the dipshit comment came from. ;)
touche' :)
:dancing:
