Posted January 22, 201115 yr i want to hook this up to my computerhttp://www.amazon.com/dp/B0002KVQBA/ref=asc_df_B0002KVQBA1401408?smid=ATVPDKIKX0DER&linkCode=asn&creative=395093&creativeASIN=B0002KVQBA&tag=cnet-3769-20 Edited January 22, 201115 yr by markak134
January 22, 201115 yr It'll more than likely be pretty boomy, I know my Polk sub that way similar to that was...to the point of annoying. If you want it for gaming, where you'll be hearing explosions and such, I'd look elsewhere, or just build your own.
January 23, 201115 yr Author i had an old cerwin vega subwoofer i could of made my own too bad i gave it away to some oneyea i want a sub that would be for games and stuff on the computerim going to need highs i need like a package that comes with speakes and a sub and i want to spend 100
January 23, 201115 yr I was going to point you towards madisound.com, who had these nice Aura ones for sale...sold out though.https://www.madisound.com/store/product_info.php?products_id=9007
January 23, 201115 yr if i were you...... i would build my own.... you could buy a 240 watt plate amp for 99.00 ........... http://www.parts-express.com/pe/showdetl.cfm?Partnumber=300-805 ...... then you could buy a 10 or 12 inch SSA Dcon for 125.00 or 115.00 ... http://www.soundsolutionsaudio.com/store/categories/Sub-Woofers/SoundSolutionsAudio/ and i bet it would sound alot better then any of them you would buy for this price... it is easy enough to buid a box for one.. i built mine with 2 12" Dcons and it is unreal how good it sounds for the price.... you can allso buy a cabinet... http://www.parts-express.com/wizards/searchResults.cfm?srchExt=CAT&srchCat=603 ... and it is great to be able to say I built it Edited January 23, 201115 yr by millertime
January 23, 201115 yr it is pretty easy to build a box.... pick what sub you want and figure out if you want it sealed or ported.. most manufactures say if there sub is better in a sealed or ported enclosure.. then they will say how big of a box... SSA is really good at telling you Enclosure Recommendations: see below.. then if you go to like re box calculator you can change the numbers that are in red and it will calculate tthe box size and tell you how box volume.. and all the info you need.. it will even give you a cut list and tell you what size to cut each piece.. you can also google anything you need to know.. there are tons of sites with pictures and articlsre box calculator http://www.reaudio.com/speaker_box/LPort_Box_Calc.htmlthis is for a 12" DconEnclosure Recommendations:Sealed: .90 cu.ft.Sealed: 1.20 cu.ft. optimalPorted: 1.75 cu.ft. @ 28-33 hzPorted: 2.25 cu.ft. @ 28-33hz opt.Sub Outside Dia.: 12.500Cut Inside Dia.: 11.150Mounting depth: 6.500Displacement: 0.14 ft^ Edited January 23, 201115 yr by millertime
January 23, 201115 yr I have a Z-5500 paired with an Auzentech Prelude X-Fi 7.1Im more than pleased with this setup. Wont be upgrading my speakers in a long time. Sound card, prob when I build my next PC.
January 23, 201115 yr Author it is pretty easy to build a box.... pick what sub you want and figure out if you want it sealed or ported.. most manufactures say if there sub is better in a sealed or ported enclosure.. then they will say how big of a box... SSA is really good at telling you Enclosure Recommendations: see below.. then if you go to like re box calculator you can change the numbers that are in red and it will calculate tthe box size and tell you how box volume.. and all the info you need.. it will even give you a cut list and tell you what size to cut each piece.. you can also google anything you need to know.. there are tons of sites with pictures and articlsre box calculator http://www.reaudio.c...t_Box_Calc.htmlthis is for a 12" DconEnclosure Recommendations:Sealed: .90 cu.ft.Sealed: 1.20 cu.ft. optimalPorted: 1.75 cu.ft. @ 28-33 hzPorted: 2.25 cu.ft. @ 28-33hz opt.Sub Outside Dia.: 12.500Cut Inside Dia.: 11.150Mounting depth: 6.500Displacement: 0.14 ft^ thank you for the input i am good at building things out of wood and ive always wanted to make my own box i just never wanted to figure out the calculations
January 30, 201115 yr i want to hook this up to my computerhttp://www.amazon.com/dp/B0002KVQBA/ref=asc_df_B0002KVQBA1401408?smid=ATVPDKIKX0DER&linkCode=asn&creative=395093&creativeASIN=B0002KVQBA&tag=cnet-3769-20My buddy has that same home theather sub its alright for the money if you want some bass but if your looking to shake the floor and have smooth accurate bass build your own and spend a little more money and time or just get a Velodyne subwoofer my 10inch 110watt vel make's that polk a joke in comparison......but 110rms for house not enough lol step up with the big boys like 1k+++ lol thats how chicks like it
