Posted January 25, 201115 yr Got a new build in works on Acura TL. Need amp recomendations for pure SQ app using very high end drivers(listed in my subwoofer thread). Rms over 1000 needed other than that just looking to upgrade my current bsheeted 1650 at 14.4 with >92 s/n ration, 83 db chan sep, and <.05%thd from 20-85ish. Also have to use an OEM integration because Acura thinks there stereo is perfect the way it is... Looking at JL's, the RF 360.2(or other versions) and a couple from audio control(all good shit). Basically looking for anybody who has installed or heard systems with these or other high quality amps and OEM int units. I think my choices would suffice but always considering better. Thanks
January 25, 201115 yr Stop citing your birthsheet. No one cares. You CAN'T hear the difference if it birthed at 1300 or 1800 anyway.You don't want all out SQ. Stop with the useless threads and give us some real information instead of terminology you don't understand.
January 25, 201115 yr Really OP, 3 threads with the same somewhat useless info for your first 3 posts???? Have you even looked at any of the threads on here??? Read up some more and then give more information and then maybe you can ask a question... It is not fun to have to read or see thread random threads about the same things...
