Posted February 4, 201115 yr What's up guys,i'm finally posting the pics of my new buildthis is for my daily driver/work truck when i go to work for my dad's plant nursery.there's no way my malibu can make it over there lolhere you guys go!!!first up the truckthese are the only truck pics i have for now lolour loading truck was full so,this is what the rest of the roses wenti told you guys,sooner or later i'm going to use the whole bed,so no blow through for memaybe walled later on =)also including the ugly rims,i hadn't changed them yet cus 24s dont go well with mud lolso 20s w/fat tires for now i'll change these ugly pics once i have the 24s on later on :good:
February 4, 201115 yr Author saying goodbye to my old system,2 kicker cvr 10s on a old kicker kx600.1i'm pretty sure everyone had CVRs and hadtheir own cvr memories,goodtimes lolanyways
February 4, 201115 yr Author AMPnow welcoming the new systemfirst up theaq3500next to my aq3500d.1INFO ABOUT THE AMP:4 ohm power @ 1% THD 750W x 11 ohm power @ 1% THD 3,500W x 11 ohm Power @ 16V @ 1% THD 4,000W x 11 ohm Power @ 18V @ 1% THD5,100W x 11 ohm Power @ 18V @ 10% THD 6,500W x 1
February 4, 201115 yr Author SUBS:5 SUNDOWN AUDIO 8sINFO ABOUT THE SUNDOWN AUDIO 8:RE: 3.28 ohms (series)FS: 41.6 HzQes: 0.513Qms: 6.606Qts: 0.476Le: 2.778 mHVas: 3.285 LBL: 17.138 N/ACms: 83.341 um/NMms: 175.654 gSens: 78.476 dB @ 1w/1mPower: 400 RMSDepth: 5.25"Overall basket OD (no gasket): 8.25"Cut-out diameter (without gasket): 7.375"Cut-out diameter (with gasket): 7.25"Magnet diameter: 6.25"XMAX: 16.5mm one way
February 4, 201115 yr Author SUB BOXES/DESIGNJud's Design(Fallen)5 didn't fit afterallso I ended up doing 4(big thanks to 99s10walled for helping me out on the boxfor the lanes
February 4, 201115 yr Author BATTERIES:bought them off from elvis(rosevillan)he gave me a newer and older model lmao
February 4, 201115 yr Author ACCESORIES:stereo dash kit,harness,red stinger volt meter,50ft of knu wiring & termlab
February 4, 201115 yr Author The Building starting off with the battery bracket =)saying good bye to my red optimatook out the old stock battery bracket and going to replace it with a new custom onefor the hc2400,i had to move the car's computer a little downermaking the special bracket,my phone died so i let it charge for a bit and took pics asapwhen I had the chance,this is where i catched up totwo brackets were welded together already,so we just need the side bars & bottom stands to support the weightof the batterieswe tried it first on the truck to see what we needed to reinforce,we noticed that the ac pipe had to be cut a little shorter for the 2nd batteryto fit in just right,so we knew that it had to be done later on
February 4, 201115 yr Author now time to cut the coolant hose,also i had to push that little red box all theway to the back so the 2nd battery could fit in there
February 4, 201115 yr Author success!but i didnt like the two different batteries lol,i bought another hc2400 4m julio to match the other oneran out of ground wire lol,oh well i'll fix that later on,still does the samejob
February 4, 201115 yr Author i cutted out the stock plastic thing that comes with the truck,it comes out easily and took the stinger volt meter apart,the stinger's black plastic is now the truck's stockreplacement.I also took apart one of my blue stinger volt meter's glass that wasn't workingand placed it on the front of the plastic instead of the red one. It was too bright,that's why I used the blueglass to dim the red display,little things make a difference =)
February 4, 201115 yr Author did a quick vid of the current set up i have in the silveradountill i finish fiberglassing the daily boxenjoy
February 12, 201114 yr good job on the dual battery tray, I'm thinking about doing the same for my Bronco
