Posted February 17, 201115 yr This is some of the results from competitors who were using IA porductsChris Gregory12 187 15's powered by 6000 wattsRadical X2 - 148.2 dB - 1st PlaceDrive-by SPL 5 - 133.6 dB - 2nd PlaceBlake Musick3 Death Row 12's powered by 2300 wattsAmatuer Street 2 - 144.3 dB - 1st PlaceDrive-by SPL 3 - 131.6 dB - 3rd PlaceDarren Musick2 Warden 15's powered by 2 40.1'sAmatuer Street 3 - 146.3 dB - 1st PlaceLee Bogema1 Death Penalty 18 powered by 2 20.1'sModifed 2 - 149.4 dB - 2nd PlaceDrive-by SPL 3 - 130.0 dB - 6th PlaceDR Kirkland4 187 10's powered by 1 20.1Modified 5 - 148.0 dB - 2nd PlaceDrive-by SPL 5 - 125.8 dB - 5th PlaceSteve Cook2 Flatlyne 18'sSQ Best of ShowLance Wayne2 Death Penalty 21'sStreet 5 - 148.1 dB - 2nd PlaceWill Montlo1 Warden 21Modified 3 - 149.0 - 4th place Edited February 17, 201115 yr by IA2
February 17, 201115 yr Chris, I edited your post to show Steve Cook running Flatlyne 18's....just so you know
February 18, 201115 yr Who won Drive By SPL 5?KefAdam Sparks out of KY. 134.7 dBNice, what's he run?Kef
February 18, 201115 yr Wow, IA FTW! That is a lot of places! BTW, I didn't know that Flatlynes were available in 18's
February 19, 201115 yr Author Wow, IA FTW! That is a lot of places! BTW, I didn't know that Flatlynes were available in 18's Me neither. But hey when you work with a company like IA who builds their products in house, custom built subs can be done.
February 20, 201115 yr Me neither. But hey when you work with a company like IA who builds their products in house, custom built subs can be done.Yes, very true! I am curious to have seen/heard how they sounded and the power/enclosure details.
February 21, 201115 yr Author Me neither. But hey when you work with a company like IA who builds their products in house, custom built subs can be done.Yes, very true! I am curious to have seen/heard how they sounded and the power/enclosure details.I know Steve Cook's Avalanche took SQ Best in Show @ Finals in 2008. I have heard the truck. I sounds awesome and is very dynamic. The subs are very accurate for being 18's.
February 21, 201115 yr Me neither. But hey when you work with a company like IA who builds their products in house, custom built subs can be done.Yes, very true! I am curious to have seen/heard how they sounded and the power/enclosure details.I know Steve Cook's Avalanche took SQ Best in Show @ Finals in 2008. I have heard the truck. I sounds awesome and is very dynamic. The subs are very accurate for being 18's.Sounds impressive, I think I've heard of these drivers used so many type of enclosures, to include IB
February 22, 201115 yr This is some of the results from competitors who were using IA porductsDarren Musick2 Warden 15's powered by 2 40.1'sAmatuer Street 3 - 146.3 dB - 1st PlacePlease forgive me because I do not know much about Meca comps, but doesn't this seem like a pretty low score for such a potent setup? I guess I just thought 2 warden 15's and 2 40.1's would have a better showing.
February 22, 201115 yr This is some of the results from competitors who were using IA porductsDarren Musick2 Warden 15's powered by 2 40.1'sAmatuer Street 3 - 146.3 dB - 1st PlacePlease forgive me because I do not know much about Meca comps, but doesn't this seem like a pretty low score for such a potent setup? I guess I just thought 2 warden 15's and 2 40.1's would have a better showing.Amateur street 3 check the rule book. That will probably tell you some of the reason why. He has to have some pretty small fusing to run those two amps and subs to combine his score low enough to be in amature street. Also only two layers of deadner. Bunch of stuff to take into consideration. But also amature street means it's your first season too. Correct me if I'm wrong on any of this. I'm still very new to meca and competing
February 23, 201115 yr Author This is some of the results from competitors who were using IA porductsDarren Musick2 Warden 15's powered by 2 40.1'sAmatuer Street 3 - 146.3 dB - 1st PlacePlease forgive me because I do not know much about Meca comps, but doesn't this seem like a pretty low score for such a potent setup? I guess I just thought 2 warden 15's and 2 40.1's would have a better showing.Amateur street 3 check the rule book. That will probably tell you some of the reason why. He has to have some pretty small fusing to run those two amps and subs to combine his score low enough to be in amature street. Also only two layers of deadner. Bunch of stuff to take into consideration. But also amature street means it's your first season too. Correct me if I'm wrong on any of this. I'm still very new to meca and competingYou are correct. The testing is done with the vehicle off with only 2 batteries that may contain no higher CCA rating than 1200 a piece. The vehicle is a full size Ford Bronco with the install located in the rear cargo area. The vehicle is only allowed to use 2 80 amp ANL fuses. I believe the install is capable of a lot more, just the competitor is as said before a 1st year competitor and still learning the vehicle. Also the score is taken from playing a musical track as required by MECA AS3 competitors. The vehicle also peaks a 32 hz.
