February 18, 201114 yr all u really need to do is put the subs in the box and connect them to the amp...
February 18, 201114 yr Author yea pretty much. i just have to make sure i have enough wire to wire everything the way i want to wire them and get the rca's
February 19, 201114 yr Author yay. i want now. that shit looks super wide though. hopefully the guy built it to the right width
February 19, 201114 yr Author ok cool. 30 is perfect. it looks way longer than that but if its 30 then thats perfect.
February 19, 201114 yr Author dash kit will be here mondaydeck will be here tuesdaypicking up second amp and box from SIC Noma tomorrowstill need to get 1 foot rca cable
February 21, 201114 yr Author UPDATE:here is a picture of my new box with both amps mounted to the top and the power/ground wires plugged into the amp and the stinger splitters. i need to cut the power/ground wires to the correct length so it will look nicer but for now this will workshitty phone picture
February 21, 201114 yr Author yes that is a big ass box of cheezits.no those are not cheezit crums. its sawdust
February 23, 201114 yr Author here is the new deck and voltmeter installed with a switch. right now the meter is being held on with double sided tape the the cubby. but im going to get a peice of splastic and cut a square whole in it and then mount it in that and glue that to the cubby
