can someone design me a box for two sundown audio zv.2 15's that will be going in a 04 impala here are the measurements
W-35
H-17
D-30
i used the subwoofer calculator on the 12volt and i came up with 8 cubes
I think you'll need to add a little more info. Such as sealed? ported? tuned to? what music you listen to most? goals? power available? and so on...
Just my opinion.
Chad
Ported for daily deep bass I listen to mostly rap and a little r&b...tunning probably @32 . As for power I have 3500 watts on hand
best i could get out of those after all displacements was 4.93 @ 32hz, not nearly enuff for 2 15s
what are u using?
torres.... thats after sub, port, and bracing displacement
