Posted February 19, 201115 yr Hey all.I have a question about wiring subs.I have 2 dual 4 ohm subs.Now I know to wire to 1 ohm i would connect + to + and - to - on each sub then run a wire from the + on one sub to the + on the other and the same thing with the -.Ok here is my question.I just got a different box today.I dont have enough speaker wire to do it the way i mentioned above and plus i would ave to run the wire behind the port and I dont know if that would be ok or not.So what i did was wire each sub to 2 ohm by itself by connecting + + and - - on each sub.SO,when i connect both subs to my amp that way will it still be a 2 ohm load or what will he load be?Thanks
February 20, 201115 yr If you wire each sub like above and run wire from each sub to each amp terminal you would have a 1 ohm final load because your amp will drop it internally.
