Posted March 12, 201115 yr The ones in the better install, but I wouldn't be interested in the Re's.What fronts?Right now I have Pioneer TS-A6871R speakers in both front and back. I'm just looking for a sub or 2 to fill the missing bass.If you want to make the biggest SQ difference you'll start by changing those up, then worry about the sub. In the SQ realm the sub is least important part of the equation.I'm content with the speakers that I have right now. Later on if I need better speakers then I will get them...later. For me the sub is important. I wanted a nice sound quality sub for my system.You didn't quite follow. If you want SQ AT ALL your fronts need updating and the rears removing. No sub will help you have any until that is addressed. No real such thing as an SQ sub either, just an alignment and an integration into the rest of the equipment. Sure some are more geared towards alignments that are better for integrating into an SQ install, but that difference is somewhat trivial.M5...sorry I snapped at you a little bit. What kind of front stage should I look into? My price range is between 300-400 dollars. I should also mention that my truck came with an audio system built in it. Ford and Pioneer teamed together to come up with the Tremor package for the Ranger. So it came with an amplifier (specs unknown) that run the front speakers and the subwoofer (10" in a 1.2 ft^3 enclosure). I want to try and buy everything together. So what sub would you recommend? What component speakers would you recommend? And what amp to power the sub (I want a separate amp for the sub bc idk what the specs are for the amp in my truck)? I could also take pictures of the amp that is in my truck now if that'll help.
