Posted March 14, 201115 yr I have some final questions for my box build. I wanted to use two 8" aero ports that i was going to run through the rear deck to the box. Both ports will have to be 32 inches long which is two long. If i switch to two 6" will that be enough port area for two z 15's? I need to switch to a smaller diameter ports so they will be shorter. What are the pros/cons of doing this?
March 14, 201115 yr Pros, shorter port smaller boxCons, port noise and perhaps some measurable (although probably not by ear) loss in output
March 15, 201115 yr Will it hurt if I put an elbow on the aero ports to get the full lengthNot ideal, but it works
