Posted March 28, 201115 yr I was going to order my d3100 for my saz3500 tomorrow but i see a lot of good talk about the deka 9a31 and the 8a31. Will i come out better by getting two of the dekas over one d3100?
March 29, 201115 yr http://www.caraudio.com/forums/wiring-electrical-installation-help/352593-kinetic-hc2400-deka-intimidator-9a31.html
March 29, 201115 yr http://www.caraudio.com/forums/wiring-electrical-installation-help/352593-kinetic-hc2400-deka-intimidator-9a31.htmlSo you link to a thread all about power master? I was going to order my d3100 for my saz3500 tomorrow but i see a lot of good talk about the deka 9a31 and the 8a31. Will i come out better by getting two of the dekas over one d3100?I think the two Deka's would out do a single D3100. I have the Deka's and they are very nice, I'd dare say AMAZING for the price.
March 29, 201115 yr Anyone use O'Reilley AGMs, rebadged Intimidators?Didn't know this. What I DO know is I had an interview at O'Reilley's today.
March 29, 201115 yr I've built several O'reilly's auto parts stores in New Mexico, Oklahoma, Texas and Louisiana but don't know shit about their batts.
March 29, 201115 yr Anyone use O'Reilley AGMs, rebadged Intimidators?Didn't know this. What I DO know is I had an interview at O'Reilley's today.someones gonna get some good discounts
March 29, 201115 yr He was asking for opinions.The masses seem to agree on Xs.But for the difference in specs the d3100 is better.Is it worth the money? If you have it i suppose.deka-Cold Cranking Amps 800Cranking Amps 1000Reserve Capacity 190Amp Hour Rate 100d3100-# 1,360 cranking amps# maximum output: 5,000 amps# 110 amp-hours
March 29, 201115 yr He was asking for opinions.The masses seem to agree on Xs.But for the difference in specs the d3100 is better.Is it worth the money? If you have it i suppose.deka-Cold Cranking Amps 800Cranking Amps 1000Reserve Capacity 190Amp Hour Rate 100d3100-# 1,360 cranking amps# maximum output: 5,000 amps# 110 amp-hoursYou just showed more reason as to get the Deka'With the Deka's you'll have 2,000CA over the Xs 1,300With the Deka's you'll have 200AH over the Xs 110And STILL probably spend less money.
March 29, 201115 yr Because he said he would be getting 2 deka's vs 1 xs... So 2 deka's is 200 vs the 110 of 1 xs.
March 29, 201115 yr what? lol where r u getting this math from?So much fail. I was going to order my d3100 for my saz3500 tomorrow but i see a lot of good talk about the deka 9a31 and the 8a31. Will i come out better by getting two of the dekas over one d3100?
March 30, 201115 yr 2 dekas would be better then one d3100 of course... the orileys yellow tops are 45 amphours.
March 30, 201115 yr 2 dekas would be better then one d3100 of course... the orileys yellow tops are 45 amphours.IDK what my front one is but my rear oreilleys are 100aH
March 30, 201115 yr alright I dug out my receipts for you guys and found my three battery receiptsSSB AGM31T 189.99 plus $5 core SSB 34/78EXTAGM 139.99 plus $5 coredoesnt say what the aH is for the front one, the SSB 34/78EXTAGM 139.99 plus $5 core, but the rear ones, SSB AGM31T 189.99 plus $5 core, are 100aH eachSo I spent $530 for three batts, two huge AGM 100aH for the back and a normal sized AGM for the front.
