on the new lincolns it kind of a cunt to put normal hid conversions in.. sooo i found these http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=110541229492+&viewitem=
and i was wondering if anyone else has used them.. perhaps you can tellme a bit about it.
Just says its for the bulb. Would still most likely need a ballast with those. What kinda problems are you having?
on the new lincolns it kind of a c-word to put normal hid conversions in.. sooo i found these http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=110541229492+&viewitem=
those are just the bulbs. I've done installs with those style bulbs and ballast mounting before with very little issues. they look great when done.
ah.. i kinda red plug and play on this site http://dealnay.com/1049329/xenon-hid-d1c-d1r-d1s-headlights-light-bulbs-blue-10000k.html
i can kinda see now it keeps saying BULB....
here is the problem i am haveing... the headlight is a all in one.. incased deal.. and it had 1 9 pin plug in for each side. an you can see in the pic circled ....
http://www.autopartswarehouse.com/popup/?type=moreℑ=L2ltYWdlcy9wcm9kdWN0X2ltYWdlcy9pbWFnZXMvcmVwbGFjZW1lbnQvbDEwMDEwNl8xZnRiay5qcGc=&title=UmVwbGFjZW1lbnQgSGVhZGxpZ2h0&text=SEVBRExJR0hUIEFTU0VNQkxZLCBDTEVBUiBQTEFTVElDIExFTlMgLS0gQnVsYnMgaW5jbHVkZWQ7IENvbXBvc2l0ZSwgY29tYmluYXRpb24sIGFuZCBoYWxvZ2VuIHR5cGU7IERPVCBhbmQgU0FFIGFwcHJvdmVkOyBBIGhpZ2ggcXVhbGl0eSwgT0UgcmVwbGFjZW1lbnQgaGVhZGxpZ2h0IGFzc2VtYmx5OyBCYWNrZWQgYnkgMS15ZWFyLCB1bmxpbWl0ZWQtbWlsZWFnZSB3YXJyYW50eS4=
so i would have to drill the back cover of the headllight cover, so i can put the wires out.. to power the ballest.. then run the hot wires back into the headlight cover and hope like hell i can get it sealed again.
and i have to do it twice on each side.. for high and low beams.
I have the exact same problem on my rover. The beams are sealed. I found some lenses that weren't sealed just for HID kits, etc. I'm not sure about Lincolns, but I bet you could find a set somewhere.
has any one ever cut the wire from the ballast too the bulb ? it always says "do not cut"
