It'll be 3 cubes after port and sub displacement.
Box size can be smaller i believe if you use an aero.
I seen a vid on youtube a while back and some dudes in russia had an sa 15 ported in a fiberglass enclosure. ..lemme try and find it
It sort of looked like this
Edited by eggyhustles
Fine. I'll be porting it. Now just not sure how I want it to look, because theres no way I'm going to fiberglass it into the tire well with backfiring ports and still maintaining a flat top.
New idea will be to put the amps in the well with a plexiglass window and the sub box on top, but as to how it will look I'm not sure. The layout in the opel isn't bad, but I want it to be moveable if it's going to be above the floor taking up room.
Car's a hatchback, would firing the sub straight up or directly at the rear glass make much of a difference in sound?
Also, would having the port at the bottom of the box make a difference as opposed to being to one side?
I always got the best results with sub up port forward in a hatch.
As long as the port isn't blocked by anything, you should be good
I'll take the lack of responses to mean that port location doesn't matter.
For a box with net volume of 3 cubes, does a port of 12H X 2W x 17.5L sound right for tuning to 31Hz?
I've been seeing that you want between 10-16" port area for every cube, but doing so would require a port length of just over 27" (with port area 12"H x 3"W)
This is what I've come up with so far, sub will be firing upwards
Port is around 3"W x 14"H x 32.5"L tuned to 31Hz
Box size is around 3.1 cubes
Any comments about if the port seems right, or if I should add some bracing are more than welcome
Box dimentions are 30L x 20W x 15.5H"
I'm doing this based of some google searches so I'm hoping for the best. If anyone could pitch in who builds these for customers just so I can get a double check before I pay for this?
