Posted April 16, 201115 yr As per title lads, with my equipment coming soon I wanna go with the loudest design possible, will be using 2 AA Mayhems with 2 Hifonics 2607D's to power them, have a nice bit of room to play around with (say a max of 25-30cuftexternal) Will I go flat wall Port up top?? Flat wall port drivers wide?? Clam?? Small Tunnel?? I'm not really pushed about numbers as I want this to rattle people (will tune to maybe 30-32hz)All suggestions welcome guys
April 16, 201115 yr Are you going for all out SPL competition or mostly a daily driver with an emphasis on ear loudness and hair tricks?
April 17, 201115 yr i say do the box just like your pic except have the port on drives side.however that loos likje a hatch, and if it is i always posted the highest score doing sup up port up and on drives side in my hatch
April 18, 201115 yr Author Well this is going to be walled with the 18's you see, just wondering guys that went from flat walls to Clamshells, Tunnels etc did they see much of a gain, although ultimately I just want it brutal on the ears not looking for numbers
April 18, 201115 yr Generally walls will have the port firing on the drivers side here in the States. If your in Ireland that might be passenger side. B or C pillar wall?
April 18, 201115 yr Author But is that the case so its loud on the mic or loud on the ear?? It will be a B Pillar wall Edited April 18, 201115 yr by QuinnyGT
