Posted April 25, 201115 yr im going to be using a hifonics brz 2400 watt model amp, am i ok running just 1 strand of 0 gauge wiring to the battery or should i do 2?
April 25, 201115 yr one.1/0 that long is plenty for an install like that..Don't overkill unless you are competing seriously.
April 25, 201115 yr i've read 1 run per 100a draw...but thats prolly overkill.http://clang4l.net/calculator.html
April 25, 201115 yr Hopefully you meant 1 run of 1/0 instead of one strand! But stated above 1 run of 1/0 should be just fine!
April 26, 201115 yr Author thanx guys, i wont be competing at all, just a daily driver..but im of the mind set, if your going to do something then do it right..i want to make sure i have all my corners covered
April 26, 201115 yr Sorry to thread jack but I got 2 gage wire for the big three cuz it was cheaper I only have one 1200 running at prob 6 or 700 watts you think that's will work
April 26, 201115 yr yea.. 8awg or even 10awg would of probably worked just as well too.Again, don't buy into the overkill hype unless you are competing.
April 26, 201115 yr i've read 1 run per 100a draw...but thats prolly overkill.http://clang4l.net/calculator.html100 amp per 1/0 wire? That's..... um...... interesting.
April 26, 201115 yr read it somewhere on termproI've always been told and read a single run of 1/0 is capable of 300+ amps.
April 26, 201115 yr I've read/heard the same about the 300+ amps... But maybe for things like serious/competition vehicles you don't rely want to rely on one run of wiring...
April 26, 201115 yr I've read/heard the same about the 300+ amps... But maybe for things like serious/competition vehicles you don't rely want to rely on one run of wiring... Of course not, but a serious vehicle would have more then one alt so would require more then one run.
