Posted May 11, 201114 yr ok, the problem is there is a noticable humming noise comming from my t1500-1bd, and its from the amp, not speakers nor subsit is a high pitch noise, and the worst is that when i turn the bass knob, the bass is louders, but then suddenly you start hearing the pitch noice more, and distorts, thats when i need to lower the bass knobsany suggestionsthanks
May 11, 201114 yr ok, the problem is there is a noticable humming noise comming from my t1500-1bd, and its from the amp, not speakers nor subsit is a high pitch noise, and the worst is that when i turn the bass knob, the bass is louders, but then suddenly you start hearing the pitch noice more, and distorts, thats when i need to lower the bass knobsany suggestionsthanksYour ground is good? Paint scraped off, bare metal?
May 11, 201114 yr if you have another amp laying around you could try swapping them. if the other one does the same thing your wiring may be the problem, if it works fine your amp may be damaged or something
May 11, 201114 yr Author if you have another amp laying around you could try swapping them. if the other one does the same thing your wiring may be the problem, if it works fine your amp may be damaged or something yea, i have another one, but its a 150 rms quantum amp, so i really dont think it will make a difference checking it with that amp, but thats my opinion
May 11, 201114 yr I would check all of your wiring first...You dont want the wires just laying all around on top of eachother. And make sure you have a good ground.I had a humming noise that would hum along with my rpms as i drove, very high pitch and annoying. All I did was re-ground my amps and made sure all my wiring was seperated and it went away... Edited May 11, 201114 yr by Jack3d SPL
May 11, 201114 yr If it is a real high pitched squeel coming from the amplifier itself and not through the speakers it is the torroids screaming..It happened on some of the 800.4's and the 1500's...nothing you can do about it either.
May 11, 201114 yr If it is a real high pitched squeel coming from the amplifier itself and not through the speakers it is the torroids screaming..It happened on some of the 800.4's and the 1500's...nothing you can do about it either.mine was through the speakers, thankfully...
May 11, 201114 yr Author If it is a real high pitched squeel coming from the amplifier itself and not through the speakers it is the torroids screaming..It happened on some of the 800.4's and the 1500's...nothing you can do about it either.So its the amp thats bad, should i return it, i bought it off from sonicelectronix
