new job way more cash! ok so i have been planing a build with some skar 12s changed my mind to put 4 ia ported in my trailblazer. well i did the big 3 i can tell a diff, but thats on a single dr. right now im trying to get the power to put 4 of them. ill be getting 2 kinetik batts under the hood and then another big one in the back. i plan on putting about 1kw max to each sub, also getting a ho alt. kinetik has a charging system also would i need oreven want that? then my trunk space is wide not so long would i be better off walling with them or a sub up port back deal. im not really wanting spl or sq more of a mix of both. im waiting for crescendo comps to come back out or maybe the ia comps def on how good they are for the front stage. (not that audio related but am looking at black 24s also its a murder project all the emblems are black windows also and will be balcking the fog and tails and painting the headlight surroundings) so to sum up would it be a good move to get the kenetik charging system, wall or no wall.
edit:death row 12s
Edited by steveo50
Do you want to have a wall?
You don't need the Kinetik charger.
ok so no on the chargers. i kinda want a wall i kinda dont.
:sleepwerd4: I would only do a wall if I was dead set on having a car basically dedicated to audio or shows, etc. If you are unsure about it, you probably don't want to wall it off.
There will be others who will tell you to go for it. Just remember that they don't have to buy your fuel and drive your vehicle. (mpg will go to shit, car will not handle as well, ride firmness will increase, brakes will wear faster and not stop as well, shocks, struts, bushings, etc. will need replaced more often, acceleration will decrease, no more passengers/groceries, etc.)
Just my $.02
