Posted June 9, 201115 yr http://tucson.craigslist.org/ele/2429693852.html I hear they're the best ever!! Is this true?? Funniest one I've seen in a while. Edited June 9, 201115 yr by ricksi30
June 9, 201115 yr Well, I see a wooden structure and I'm pretty sure it's just been glassed and mudded. Clay would be too brittle.
June 9, 201115 yr Admin Funny it says "made to spec", to what specs? lolthats right in your back yard.. you should check it out lols
June 9, 201115 yr Funny it says "made to spec", to what specs? lolthats right in your back yard.. you should check it out lolsI can use it for when I'm camping OP is close too
June 9, 201115 yr Admin Funny it says "made to spec", to what specs? lolthats right in your back yard.. you should check it out lolsI can use it for when I'm camping OP is close too there you go. a brand new/used toilet for your house
June 9, 201115 yr Funny it says "made to spec", to what specs? lolthats right in your back yard.. you should check it out lolsI can use it for when I'm camping OP is close too there you go. a brand new/used toilet for your house Maybe he has a lcd I can get to go along with it
