This thing is so powerful it's hard to get started, especially since I want out of the ordinary responce, not flat. Since it has 1/120th control I don't know where to start with Q... 60/120? Thats the default IIRC. I basically need to lower everything boosting nothing as I need to create a LP effect. I want 5Hz-10Hz to be 6dB above 11Hz-18Hz. I want 11Hz-18Hz to be 6dB above 19Hz-30Hz. I want 19Hz-30Hz to be 6dB above 31Hz-250Hz.
This is all guesstimation, obviousely not a 6dB drop between 1Hz increments... just to give an idea of what I am after. I may simply center at 45Hz and EQ down 24dB and vary my Q until I am happy, unless I get some good feedback.
Thank you for trudging through this post, trying to understand it, and if you even reply with help... thank you very very much.
KW
Filter 1: 40Hz -48dB Q 60
Filter 2: 20Hz +16dB Q 120
Filter 3: 20Hz +16dB Q 120
Filter 4: 20Hz +16dB Q 120
Filter 5: 20Hz -16dB Q 60
Filter 6: 20Hz +16dB Q 120
Filter 7: 20Hz -16dB Q 60
Filter 8: 20Hz +16dB Q 120
Filter 9: 20Hz -16dB Q 60
Filter 10: 20Hz -16dB Q 60
Filter 11: 40Hz -48dB Q 60
1st problem: as I was adding the last 2 filters I noticed rumbling got loud when I added dB, then i realized 1 side was doing it but not the other, before I saved it, though both engine lights are on. When I did the following cut it fixed it...but that doesnt mean they became symetric again. So I did sine waves at 6.5Hz, 10Hz, and 16Hz to make sure both sets of subs have the same excursion. They do. However, at 6.5Hz when I get it loud enough to get amplifier noise, it was on the same side that suffered rumbling. :(
Anyway....
the 2nd -48dB cut at 40Hz killed it:
but then the last filter, 12, boost 16dB at 20Hz Q of 120 fixed it and I am happy for now.
Final sweep
I started to remove several filters as there was too much 5Hz-10Hz and everything else was dead, as I removed the 2nd 40Hz the buzz came back, and only on 1 side. Something is wrong so I took the BFD back out. Ran Audyssey for the 1st time, IDK who's system this is...but its totally different...instantly.
Here's sweeps starting at -35dB in 5dB increments to -20dB and I still have a TON of headroom.
Audyssey set all speakers to negative something, the sub was -12dB. I swept it again with -9dB then -6dB and still have headroom, but not much, so i will leave them at -6dB
just ran another sweep with the entry way door sealed up. So much for retuning higer, work on more bracing and more sealing up and I should be golden to 5Hz.
Little vid i made of REW and a couple sweeps, a lot of people that subscribe to my vids have no idea what REW is, where I get my numbers or graphs.
110dB from 5Hz up REW Room Eq Wizard.AVI
  • 3 weeks later...
Tuck in that tummy ya hillbilly.
Thanks for sharing.
of course it has to take the snapshot for the vid right there.... damn it man!
Nice room
