Posted June 28, 201114 yr I've been looking around most of the forums and the only replies are "I wouldn't do it", but the question is never answered. Is it as simple as strapping two similar amps per coil or is there more to it.Also, can you put more than two amps per coil. If so, how. Thanks
June 28, 201114 yr that meaning the amps have to be strappable correct, which really means that the gains are the same?
July 13, 201114 yr Well you can strap em and run them that way. But you need to make sure you sub wont be wired too low for the amp to handle. And you can also run each amp to each coil, but that would only work if you sub has 4 coils. We need to know the equipment to give you more input.
July 13, 201114 yr You can do it without a problem, if you have the right equipment and the right know how.
