Posted June 29, 201115 yr Which sub will perform better: RE Audio SRX Electrical Q Value -Qes: 0.45Mechanical Q Value -Qms: 4.87Total Speaker Q Value -Qts: 0.41Free Air Resonance -Fs: 23 HzEquivalent Compliance -Vas: 203 litersOne-Way, Linear Excursion -Xmax: 18 mmEfficiency -SPL 1W/1m: 87.6 dB SPLEffective Piston Area -Sd: 810 cm^2DC Resistance -Re: 1.8 ohmNominal Impedance -Znom: Dual 4 ohmThermal Power Handling -Pe: 300 WForce Factor -Bl: 14.35IA 187In the same order as above:Qes: 0.85Qms: 4.76Qts: .72Fs: 35hzVas: 105lXmax: 22mm peak to peakSpl: 89.2dbSd: 800DC Re: ??Impedance: dual 4Thermal power: 300w rmsBl: 17tm
June 29, 201115 yr Author RE Audio recommends a ported box from 2.5 cuft to 3.0cuft. My box is 2.89cuft, so I'm good in that regard. But I dunno what IA said about that because the web site do not tell anything about the 15" 187.
June 29, 201115 yr Define "better" and maybe someone can help you. Without knowing what it is you want no one can help.
June 29, 201115 yr i'm not sure about Incriminator but i do know RE SRX is made oversea's, not that it's a bad thing, i'm just not very impressed with RE's lower lines anymore IMHO.
June 29, 201115 yr Author Better: more reliable, good performance ""SQL"" type of thing. But forget it. I'm going with IA. I found the box recomenndations here and they also go from 2.5 cuft to like 3.0cuft. So it works for me. Thanks!!
