Posted July 1, 201114 yr Vehicle Make and Model: 2008 Saturn VueDirect of Box/Subs: Towards the rear/hatchSealed or Ported: PortedNumber of Subs: 2Brand and Model of Subs: Tang Band W8-740PMax Dimensions: 36" wide/14" tall/not sure on depth, but as shallow as possiblePort Color: BlackFlush Mount Ring Color (if flush mount is chosen): N/A Carpet Color: No carpetZip Code for Shipping Quote: 66523Any other notes: I want to keep this enclosure as small as possible. I'd rather go wider and/or taller, and keep the depth down to a minimum.
July 3, 201114 yr Do you have your heart set on ported? If you do the port will take up more room than the enclosure. Andrew Edited July 3, 201114 yr by Argent Audio
July 3, 201114 yr Indeed, small and ported do not go hand in hand. Unless of course you love port chuffing and don't care about the gains you get from a port.
July 4, 201114 yr Author Thanks, guys. I had wondered about it being too small to port. I have no problem going sealed.
July 5, 201114 yr Author I've decided to go a different route, but still need a quote. Should start a new thread or just use this one?
