Posted July 8, 201115 yr i have a sundown 2000d amp and its going in a ram 2500 which has 2 batteries under the hood. am i going to need to put a Kinetik battery in the back by the amp to keep it cool and to avoid any damage to my amp. it will by pushing a nightshade 12 v.2
July 8, 201115 yr Nobody can tell you for sure, install it and see if you have significant voltage drop.
July 8, 201115 yr i have a sundown 2000d amp and its going in a ram 2500 which has 2 batteries under the hood. am i going to need to put a Kinetik battery in the back by the amp to keep it cool and to avoid any damage to my amp. it will by pushing a nightshade 12 v.2Couldn't hurt none ... BTW ... Welcome to SSA !!! Where you live in Mississippi ??
July 8, 201115 yr With just 2 batteries on 2000 watts you will more than likely have some voltage drop. Seeing as how your truck is a 2500, it probably has a pretty large alternator, so I could be wrong. I'd do what Ohjay said and install it first. If your voltage is dipping when bass kicks in, another battery wouldn't hurt. Also be sure to do the big 3, it helps a lot. Edited July 8, 201115 yr by burko
July 9, 201115 yr Author With just 2 batteries on 2000 watts you will more than likely have some voltage drop. Seeing as how your truck is a 2500, it probably has a pretty large alternator, so I could be wrong. I'd do what Ohjay said and install it first. If your voltage is dipping when bass kicks in, another battery wouldn't hurt. Also be sure to do the big 3, it helps a lot.what is the big 3?
