July 14, 201115 yr Author Install is going to be a significant part of getting to 150db!Cone and port area are the key!Does it look like I'm on the right track with cone area?yeahOkay so I'm on the right track I know that.
July 14, 201115 yr Install is going to be a significant part of getting to 150db!Cone and port area are the key!Does it look like I'm on the right track with cone area?Yes!
July 14, 201115 yr There are a lot of quality choices out there. The SSA Store carries some very good candidates and other vendors on the forum have some options!What would you recommend?I am partial to Sundown. But I have run Incriminator, Fi, and SSA and niether has dissapointed. I would start with a Sundown Nightshade V.2, Incriminator Audio Death Penalty, SSA ZCON, FI BL etc.What type of vehichle?
July 14, 201115 yr Author There are a lot of quality choices out there. The SSA Store carries some very good candidates and other vendors on the forum have some options!What would you recommend?I am partial to Sundown. But I have run Incriminator, Fi, and SSA and niether has dissapointed. I would start with a Sundown Nightshade V.2, Incriminator Audio Death Penalty, SSA ZCON, FI BL etc.What type of vehichle?Its a 2000 Honda crv.
July 14, 201115 yr There are a lot of quality choices out there. The SSA Store carries some very good candidates and other vendors on the forum have some options!What would you recommend?to be honest for the money its hard to pass up ssa xcon they great power handling great quality sound and perform awesome
July 14, 201115 yr 4 Sundown SA-12" Would be a good choice but that depends on how much room there is.
July 14, 201115 yr Author 4 Sundown SA-12" Would be a good choice but that depends on how much room there is.They won't all fit in the box.
July 16, 201115 yr Xcons have been proven to be great subs, but it seems with your goals that something like a BTL or if your set on SSA then the Zcon series seems better suited to your goals IMO.
July 16, 201115 yr Author I have about 7.5 cubes to work with maybe .6 at the most so the subs would need to work best in that size box and I don't want to go any bigger than the 3500d because I dont think the electrical can handle more.
July 16, 201115 yr I have about 7.5 cubes to work with maybe .6 at the most so the subs would need to work best in that size box and I don't want to go any bigger than the 3500d because I dont think the electrical can handle more.that should be just about right for the 15s in the small ported box
July 16, 201115 yr Author I have about 7.5 cubes to work with maybe .6 at the most so the subs would need to work best in that size box and I don't want to go any bigger than the 3500d because I dont think the electrical can handle more.that should be just about right for the 15s in the small ported box Is the box not big enough?
July 16, 201115 yr I have about 7.5 cubes to work with maybe .6 at the most so the subs would need to work best in that size box and I don't want to go any bigger than the 3500d because I dont think the electrical can handle more.that should be just about right for the 15s in the small ported box Is the box not big enough?yeah i got the specs on the tech page at the top of the forum page
July 16, 201115 yr Author I have about 7.5 cubes to work with maybe .6 at the most so the subs would need to work best in that size box and I don't want to go any bigger than the 3500d because I dont think the electrical can handle more.that should be just about right for the 15s in the small ported box Is the box not big enough?yeah i got the specs on the tech page at the top of the forum page Do you think they will be happy in the space I have for them?
July 16, 201115 yr Nightshades work greattt in small enclosures. Im getting two 15s for my ford ranger
July 16, 201115 yr Hey i just noticed its shorty!! Haha wassup man! You finally got your alternator!! Ill sell you my Fi Q 15's
July 16, 201115 yr Nightshades work greattt in small enclosures. Im getting two 15s for my ford rangerHow much power can those nightshades take? My hb got 2 dd 9518's but on 3k they give iff some funky smell
July 16, 201115 yr I think they're rated 2k each. I'm sure they can take more tho Edited July 16, 201115 yr by Angelboy863
July 16, 201115 yr My friend got a freshly reconed 15" Fi btl n2 for 350. You can get another btl and have 2...lmk if your intrested.
