Posted December 29, 200519 yr PPL,I'm in the process of building an all out SPL car. (SM 3-4) Right now, I have 2 AutoTek MM4000.1's, which will be connected to 2 ATOMIC APX18D2's. (wired@ 1 ohm per sub) Being a Kinetik dealer here in Japan, I can get the 2400 Monsters at a good price.. I used the calculator on the site and it said I needed 3 of these monsters! My goal is to get full power out of the amps(burps only!) How many batteries would you suggest? and before anyone suggest other batteries, I've already looked at:Odyssey 2150NSB90 via Northstarand Optima g31 Yellow topsall comments are but experence is wanted holla when ya canTIAGavin (MERRY CHRISTMAS AND a early Happy NEW YEAR to all!
December 31, 200519 yr Author oh no Gavin is over here now waatch out already gave ya my opinion.<{POST_SNAPBACK}>yea team mate, I'm all over! seems like everyone is saying the same thing to me.. get as many as you can, or go by the rules for SM 3-4.. I give up asking this question.. I don't think I will every get a TECH answer!all I want to know is "how many amps does 1 MM4000.1 require to produce FULL POWER" do ya like my altar?? think they can feel me commin?? Edited December 31, 200519 yr by Gavin
January 4, 200619 yr Author Well, this battery thing is driving me crazy now... I'm getting some of my team mates suggesting that I use optima, and some say Kinetik.. well, I just I need help from the playerz that have used both.. if possible.. give me the PRO's and CON's of both! maybe this will help me deside..My class will be STREET MAX 3~4. My system consists of 2 apx18d2's2 MM4000.1 wired @1 ohm per sub.batteries??? you deside..holla holla
January 4, 200619 yr Well, this battery thing is driving me crazy now... I'm getting some of my team mates suggesting that I use optima, and some say Kinetik.. well, I just I need help from the playerz that have used both.. if possible.. give me the PRO's and CON's of both! maybe this will help me deside..My class will be STREET MAX 3~4. My system consists of 2 apx18d2's2 MM4000.1 wired @1 ohm per sub.batteries??? you deside..holla holla<{POST_SNAPBACK}>Why are you doing SM3-4 if you are only using two woofers?Also, I haven't read up on any rule changes...but as far as last year...it's not that hard. ONE battery for SM1-2 and TWO Batteries for SM3-4. I'm kinda torn between both. I have a Kinetik HC2400 and a D31 Optima Yellow Top in my truck right now. Tho, Scottie has told me from real-life tests...in his situations...the Optima's were "louder".NG
