Posted July 23, 201114 yr My amp is going in to protect like 20-22 seconds in the song and is not even getting warm..Anyone know what that could be
July 23, 201114 yr Author could be a loose wire, maybe low voltageI Hope Not and I just checked all connections their all good
July 23, 201114 yr Author Check the voltage when the amp cuts out on the song and rule out voltage drop!Quick Question Kind of newbish but where exactly do you clamp the DMM at....Battery????
July 23, 201114 yr Check the voltage when the amp cuts out on the song and rule out voltage drop!Quick Question Kind of newbish but where exactly do you clamp the DMM at....Battery????At the amp.
