Posted July 27, 201115 yr This is a tribute build for HelloMyNameIs at the SMD forum. His brother passed away, and since four was his favorite number, why not cram four of the new Obsidian Audio 15" subs in the back of his Jeep...right? The box will be 12.75ft^3 tuned to 34hz via four 6" aeroports. The bracing was a little tricky as I had to avoid the aeros and brace the top as well. Needless to say it took a little planning to make sure everything would work out ok.
