Posted August 7, 201115 yr Will this alternator work in my 2008 Mazda 6? Just wondering because the body styles of the 07 and 08 Mazda 6 are the same.
August 8, 201115 yr Will this alternator work in my 2008 Mazda 6? Just wondering because the body styles of the 07 and 08 Mazda 6 are the same.Which alternator? You didn't link anything here. Some of the 2.3's will interchange, some will not. You can look it up by your application on www.mechman.com. If it's listed we can build it for your application. Email [email protected] and we can get you a quote for the right unit. We are here Monday-Friday, 8:30a to 6pm Eastern Standard Time. Thanks!
August 9, 201115 yr Author Will this alternator work in my 2008 Mazda 6? Just wondering because the body styles of the 07 and 08 Mazda 6 are the same.Which alternator? You didn't link anything here. Some of the 2.3's will interchange, some will not. You can look it up by your application on www.mechman.com. If it's listed we can build it for your application. Email [email protected] and we can get you a quote for the right unit. We are here Monday-Friday, 8:30a to 6pm Eastern Standard Time. Thanks!Sorry about that this is the linkhttp://www.soundsolutionsaudio.com/store/products/220a-High-Output-Alternator-Mazda-2.3-%252d341%252d.htmlI will look at the website and check it out thanks
August 9, 201115 yr That unit is only a direct bolt-in to the 2.3 Turbo models older than your car.Email me- [email protected] -with your full application and I will see what we have available for your car. Thanks!
August 10, 201115 yr Author That unit is only a direct bolt-in to the 2.3 Turbo models older than your car.Email me- [email protected] -with your full application and I will see what we have available for your car. Thanks!Sweet I will be able to get all that information next month when I get back from my deployment and I'll email you.
