Posted August 11, 201115 yr Alright guys im looking for a little help. A guy i work with has a 97 single cab ford ranger is wanting to get a little bass in his truck. there isnt a lot of room behind the passenger seat(havnt had a chance to measure), but what would be a good shallow sub that would work well in a small sealed box? i was looking at the new sundown sd-2 but im not sure how well that would work. any ideas?THANKS!!!
August 11, 201115 yr The only shallow sub I have direct experience with is an Alpine Swrt10. Have it powered off an Sundown 1200d at 4 ohms. Very shallow mount depth. Optimal sealed box is .42^ gross. Sounds really good. Does a good job with all types of music. Does a better job ground pounding than I expected. Putting it in the wifes Escape cause I did go with the SD.2 tens. Gonna put four behind the seat. I honestly considered going with four of the Alpines behind the seat but they just cost so much.
August 11, 201115 yr What are his goals, is he just looking for a little low end extension or does he want some big bass out of it?
August 11, 201115 yr Author He isn't looking for big bass at all. He is just wanting to add a little bass. He loved the sound of my dcon but I don't know if if would fit
August 11, 201115 yr I would suggest maybe a single 10 or 12 SD2 in a large sealed box, that would probably suit him well and if he ends up wanting more, cut out a hole and stick an aero in there.
August 11, 201115 yr The Rockford Fosgate P3S is an option too! Sounds good and gets pretty loud, especially for only throwing ~400 watts at it!
August 12, 201115 yr Author well i talked to him earlier and he is cool with doing a center console box so that should make it a little easier Edited August 12, 201115 yr by bcst86
