I might have missed something, but i dont think anyone mentioned that running a larger amp such as a 2000 watt will most likely require electrical upgrades to support it.
  • Replies 103
  • Views 9k
  • well that amp is rated at 4 ohm mono for 1100 watts..... soo.... first thing is first. make sure they are indeed dual 2's then you need a new amp. somthing that put full power out at 2 ohms. IF the
  • this fucking guy.
  • hes always following me trying to give better advice.. AFTER i already asked all the questions to figure out whats going on... and i never say anything because, i dont want to stirr shit up on SSa..
How about a Sony 2ohm stable 1000watt?
doubt it does anywhere near 1000 watts
This^ The one's I have seen used tend to get hot too.
Ya the migraine kustoms guy said if and when I get a bigger amp I should go to zero gauge on power, ground and one other thing I can't think of at the moment
