Posted August 28, 201114 yr ok my speakers have been working fine. i get in my truck today and the right side is like screaming with static the left side works fine. i turn the stereo off and it stops. any ideas help?edit: i have ia comps Edited August 28, 201114 yr by steveo50
August 28, 201114 yr Check your rcas's and ground at the amp and behind the deck. Alo make sure your speaker wires are not grounded to metal.
August 28, 201114 yr Author it could be the ground but the rca is to the same channel on the amp for both sides. i think it may be the ground to the crossover is loose. is that a possibility?
August 29, 201114 yr Author Yea I plan on doing it when it stops raining, also it will like fad out so you can't hear it then it will over power the music sometimes wtf man
August 29, 201114 yr Author Its a bass pro or something like that. its a crap amp iv had for years. This would not surprise me.
August 29, 201114 yr Try another amp if you have one. That would be the easiest way to find out if it's the amp.
September 2, 201114 yr Author Thank you 98 gmc for your responses. Just jumped in the car and the static was so loud, when the radio turned on I jumped and hit my head on the roof. lol so now neither side is working just ungodly loud static. So I'm guessing its the amp.
September 4, 201114 yr Author ok so i changed the ground out 2 times check the connectionsunplugged replugged rcas in the speakers worked but poping sound when turned on/offmessed with some other grounds same thing but when i turned up the volume is made a strange mic feedback sound i guess.so any other suggestions of it it deff the amp i dont have an extra right now so im waitinf for my buddy to come drop one off
September 5, 201114 yr Author yep it was the amp its done for. any good suggestions for a amp for highs?
September 5, 201114 yr Author about 100ish maybe like 150 its only on the comps in the front soo like 100watt per channel is the most i wanted to do but no less then 85watts. idk if it matters for comps as much as subs.
September 5, 201114 yr Imo buy a quality amplifier. Stick with a more mainstream brand. For the budget AudioPipe and Maxxsonics should fit the bill nicely.Used is always a good option as well.
