Posted September 6, 201115 yr ok so i got a 2001 4runner and i need a box for a 10 downt know how much watts or even what sub yet but would slot ported be my best bet for a daily want to hit all notes but 33 or 34 hertz will be my bottom end what i want any help would be appreciated
September 6, 201115 yr You should first buy the sub then design the enclosure around the specifications of the sub.Also, tell us what music you listen to so we can help you decide where to tune the box and also recommend a woofer that will perform to your expectations.
September 6, 201115 yr Author You should first buy the sub then design the enclosure around the specifications of the sub.Also, tell us what music you listen to so we can help you decide where to tune the box and also recommend a woofer that will perform to your expectations.i listen to r&b hip hop and rap along with country also i was looking at a re se10 as well due to i can get it for 140 shipped as for amp something in the 1000 watt range idk what brand yet hope this helps
September 7, 201115 yr Author I suppose your looking for a sound quality woofer, correct?im looking for anything just louder and better then a w6 jl 10
