Posted January 17, 200620 yr I've been having a small problem with my in-line fuse. at first I had a 80 amp tube fuse in a fuse holder, under the hood. One day my subwoofer stopped working, so I pulled over to see what was wrong.My fuse holder was melted with the fuse inside. So I bought a new fuse holder and put a 40 amp tube fuse in it. Then 2 days later after playing my system loud for 10-15 min. I blew another fuse. I never had this problem before. I have noticed that at times the inside of the fuse will be glowing hot. Is this normal for a fuse to glow?Anyway if anyone can tell me what can be going wrong here, let me know.I have a soundstream Tarantula TR880/2, with 4GA wire hooked up. Ibeleive the amp draw for it was 80. I have an 80 amp stock alternator. I'm getting ready to do the big three under the hood soon to help with voltage drop.
January 17, 200620 yr Keep in mind most fuses will not blow until reaching 150-200% of their rated cut. I don't see how you're pulling that much current with that amp. I'm guess some arcing perhaps from a poor connection or internal problems on the amp.
January 18, 200620 yr Author I have checked the power wire for cracks. but maybe I need to get under the carpet to look for wire exposure.Is it possible for an amp to develope internal problems. I may check my ground wire too, but I doubt it the ground.
January 18, 200620 yr Is it possible for an amp to develope internal problems. ]Anything is possible.
