Posted September 16, 201114 yr well i was bored again the other day so i threw 1 of my oldschool kicker zr240s on 1 of my solo x's. it doesnt sound to bad. i do however have a second zr240 in perfect working order. so how would i go about wiring both of them up and linking them? i want both amps to be pushing the 1 solo x.iv never done it before and help would be appreciated. Thanks! Edited September 16, 201114 yr by Lantz
September 17, 201114 yr You could run one amp to one coil and the other to the opposite coil.As long as the amps are 1 ohm stable.Be very careful when doing this b/c you can get settings wrong and windup doing some damage to the coil.Just back the volume off if you see, smell, or hear any signs of something wrong.
September 17, 201113 yr Providing the zr won't get cranky with with the ohm load it see's, set both amps output with a DMM and test tone and hook one to each coil.
