well i was bored again the other day so i threw 1 of my oldschool kicker zr240s on 1 of my solo x's. it doesnt sound to bad. i do however have a second zr240 in perfect working order. so how would i go about wiring both of them up and linking them? i want both amps to be pushing the 1 solo x.iv never done it before and help would be appreciated.
Thanks!
Edited by Lantz
also need to know what the coil config is for the sub.
You could run one amp to one coil and the other to the opposite coil.
As long as the amps are 1 ohm stable.
Be very careful when doing this b/c you can get settings wrong and wind
up doing some damage to the coil.
Just back the volume off if you see, smell, or hear any signs of something wrong.
Providing the zr won't get cranky with with the ohm load it see's, set both amps output with a DMM and test tone and hook one to each coil.
