Posted September 23, 201114 yr Alright fellas, I just threw in the order for a dual 2 ohm death penalty!!!! It will be in my Ext cab Sierra in 9cubes at 30 hz with 151 inches of port area, what do y'all think? Is this a good box layout? Also it will be run off of 2 crescendo bc2000d's at 2 ohms then for shows .5 a piece strapped! Don't worry the electrical will be present when I throw them in.
September 23, 201114 yr Admin Sounds like you will have a bad ass set up there.Thanks for your business!
September 23, 201114 yr I'm really surprised you don't see more of the 21" builds. I hope you do a build log of yours! I always wanted one....
September 23, 201114 yr Author Yea I should be doing a build log in about 3 weeks or so, enough time to let me save up some monies!!!! I'm so pumped this thing will be a low end monster!!!!
September 26, 201113 yr Author I know right, shes really is the bomb haha. its been 4 dayz and i havent recieved a tracking number? do they build it when i order or is it already built?
September 26, 201113 yr It took a few days for my IA amp to ship out. Give them a few more business days, I bet by tuesday or wednesday, you will have a tracking number and it will be on it's way.
September 26, 201113 yr haha i wanted 2 21" subs in my car. but only 2 18's would fit in my civic hatch lol good luck with the build should hit nice and lowww
September 26, 201113 yr If you had the option you should have done Dual 4ohm. Run the amps at 1ohm each, much less strain on the system. Running .5 pulls ALOT more current for not a lot more output, and what is more output is usually dirty power.
September 26, 201113 yr Admin Thanks!!!! I appreciate it Mark.Just put your order in tonight. Should go into the build que at IA tomorrow
