Ok outa all my yrs of car audio i've never had a problem like this.
It all starts i'm drivin and i goto turn the bass up and it plays for a while then cuts off. SO i'm like no bigE mayeb a fuse or bad connection. But i'm like lets test it so i turn off the HU and turn it back on and the system cuts back on. Turn it up again and the same thing happens so no i'm thinking bad connection somewhere.
So next day i look at all the wiring and nothing seems to be a problem.
I cut it on and it plays normal. I goto close the trunk and it cuts off. lol
So i check erething again it looks fine but now a constant bass note plays wt the music even if you turn it down it continues to pulse. SO i goto turn it off and it then just gets rediculously insane like a freq note is playin. So im like sht, so i turn the car off and its still playing.
I go look at the amp and the protect light is on, the other amp for the mids is on as well but no protect light.
So i goto unplug the rca cable and they both cut off.
So my guess is the rca cables are bad.
But it seems like power is running through the rca cables i mean it sparked when i took them off. and how else could both amps stay on.
Like i said weird.
my friend had the pulse problem a while back, he said he changed all of his wires and it still did it, so he unbridged his connections and now it plays fine.
I do have it hooked up at .5 and its a 1ohm stable, but its been playin fine up unitl now and its not like its cutting off.
I'm so lost im gonna change the rca's 2ma and see what happens its too dark to see anything right now.
Good one, you broke it !
That seems a bit odd to me. Could be a H/U problem or amp problem.
well i think ur right i did break it.
I was messin around wt it, and tapped it and it started pulsing tapped it again and it stopped.
So i think somethin in the amp is loose, i'll take it apart today and have a look.
