Posted January 22, 200619 yr And it has 8" of clearance too, too bad you cant go any larger than 10's with it.Basically it ended up that i would just go around tapping it with a hammer and saying "it could use some bracing here" untill no matter where you tap it you get a short, high tap, not a thud. cant really brace any better than that. its heavy as a Bizotch too for a 2cuft box, used almost an entire sheet of MDFAnyway, its on the smaller side for the speakers it was built for which are 2 Kicker Comp 10's but low end output should be made up for for the lower than reccomended tuning (about 32Hz uncorrected and 29-30 after end corrections) and they are slot loaded so im hoping that does something for it. its the port is massive, 3.5x6.5... its going int a single cab Ram 1500
January 23, 200619 yr And it has 8" of clearance too, too bad you cant go any larger than 10's with it.Basically it ended up that i would just go around tapping it with a hammer and saying "it could use some bracing here" untill no matter where you tap it you get a short, high tap, not a thud. cant really brace any better than that. its heavy as a Bizotch too for a 2cuft box, used almost an entire sheet of MDFAnyway, its on the smaller side for the speakers it was built for which are 2 Kicker Comp 10's but low end output should be made up for for the lower than reccomended tuning (about 32Hz uncorrected and 29-30 after end corrections) and they are slot loaded so im hoping that does something for it. its the port is massive, 3.5x6.5... its going int a single cab Ram 1500<{POST_SNAPBACK}>Lemans Jr.? Got enough CAULK?!?!I would have use aero-ports...two 4"...would have made it a lot easier . Oh well...good stuff. NG
January 23, 200619 yr hah, tru dat tru datYou should rotate the pics, its anoying to turn my head to view them
January 23, 200619 yr Author Noah, you know me, i love Chaulk.... mmmMMMmmmgood.Pics = FixedI would have used Aero-ports but my friend is cheap and yeah...he told me i dont need to bondo the seems i just need to paint it...i was like "its like $5 for a small can of bondo, that is all i need." he finally agreed to give my the extra $5, lol. two $14 ports would have sent him through the roof.
