Posted October 4, 201114 yr Hey everyone I found someone selling this amp on craigslist and wanted to make sure that it is a true 2000 watt amp otherwise I know I'll be getting ripped off.The amp is:2000 watt Performance TekniqueI just want to make sure it's not similar to something like a kenwood amp that doesn't give off as much watts as what it really says.Thanks!
October 4, 201114 yr Author Nope. They are junk.About how many watts do you think it's really putting out rather than 2000?Are there any other reasons that you think it's junk besides that it probably doesn't put out 2000watts?Thanks for your help
October 4, 201114 yr audiopipe is about the cheapest company you will find that actually attempts to put out rated power @1%THD.
October 4, 201114 yr Author audiopipe is about the cheapest company you will find that actually attempts to put out rated power @1%THD.About how many watts do you think it is really putting out rather than 2000?Would it power 2 L5 kicker 12's good?Thanks again for the help!
October 4, 201114 yr How much are they asking for it? I personally wouldn't buy it for pretty much any price. Like Sizzzon said Audiopipe is decent for a budget amp. My Cadence ZRS 9 took a dump on me so I bought the AP1500 to hold me over and am more then impressed for the price of 140 shipped brand new.
October 4, 201114 yr Author Here is what someone is offering me:2 12" L5 Kicker Subs 2000 Watt performance teknique ampBox the subs are in.The wires.All for $350 but I don't know if it's a good deal or not. I'll probably just end up buying the subs and the box but not the amp. Do you think it's a good deal?
October 4, 201114 yr Here is what someone is offering me:2 12" L5 Kicker Subs 2000 Watt performance teknique ampBox the subs are in.The wires.All for $350 but I don't know if it's a good deal or not. I'll probably just end up buying the subs and the box but not the amp. Do you think it's a good deal?I'm not a huge Kicker fan but if you get the two 12's and the box for a great price it might be a good choice. If they are in good shape. As far as the amp I'd steer clear.
October 5, 201114 yr Hey everyone I found someone selling this amp on craigslist and wanted to make sure that it is a true 2000 watt amp otherwise I know I'll be getting ripped off.The amp is:2000 watt Performance TekniqueThis one.. with the single 80A fuse recommendation? Its rated at 2000wrms PEAK. That 900wrms rating is most likely inflated too.. youll probably get around 800wrms if youre luckyNope. They are junk.
October 5, 201114 yr Hey everyone I found someone selling this amp on craigslist and wanted to make sure that it is a true 2000 watt amp otherwise I know I'll be getting ripped off.The amp is:2000 watt Performance TekniqueThis one.. with the single 80A fuse recommendation? Its rated at 2000wrms PEAK. That 900wrms rating is most likely inflated too.. youll probably get around 800wrms if youre luckyI agree that the amp doesn't do anywhere near it's advertising.But how do you come to the conclusion that it does 800watts rms?Edit: I see how you calculated that. You did the amp fusing (80a) * 10 and got 800watts? Is this some trick you learned somewhere?
October 5, 201114 yr I've owned a performance teknique it's the worst amp I've ever owned. It doesn't do close to rated and it doesnt produce clean bass
October 5, 201114 yr Boo Peak rating. You could claim a 2000w peak on a 50w amp. I'd run like hell from that thing and avoid buying subs from the guy selling it. If he's that clueless the likely hood of everything being in ok shape and worthwhile is about 0%.
October 5, 201114 yr Edit: I see how you calculated that. You did the amp fusing (80a) * 10 and got 800watts? Is this some trick you learned somewhere? its kind of a trick lol... in my hifonics manual it says the brz1200 takes a 120amp fuse... the brz1700 takes a 170amp fuse... the brz2100 takes a 200amp fuse.... and my brz2400 takes a 250amp fuse... and the 3000 takes a 300amp fuse... even though i dont think they make the brz3000 anymore cause i cant find them anywhere... Edited October 5, 201114 yr by 10000wrms
October 5, 201114 yr Hey everyone I found someone selling this amp on craigslist and wanted to make sure that it is a true 2000 watt amp otherwise I know I'll be getting ripped off.The amp is:2000 watt Performance TekniqueThis one.. with the single 80A fuse recommendation? Its rated at 2000wrms PEAK. That 900wrms rating is most likely inflated too.. youll probably get around 800wrms if youre luckyI agree that the amp doesn't do anywhere near it's advertising.But how do you come to the conclusion that it does 800watts rms?Edit: I see how you calculated that. You did the amp fusing (80a) * 10 and got 800watts? Is this some trick you learned somewhere? I did 80Amps x 14.4volts x .7 for efficiency
October 5, 201114 yr Hey everyone I found someone selling this amp on craigslist and wanted to make sure that it is a true 2000 watt amp otherwise I know I'll be getting ripped off.The amp is:2000 watt Performance TekniqueThis one.. with the single 80A fuse recommendation? Its rated at 2000wrms PEAK. That 900wrms rating is most likely inflated too.. youll probably get around 800wrms if youre luckyI agree that the amp doesn't do anywhere near it's advertising.But how do you come to the conclusion that it does 800watts rms?Edit: I see how you calculated that. You did the amp fusing (80a) * 10 and got 800watts? Is this some trick you learned somewhere? I did 80Amps x 14.4volts x .7 for efficiencyPerhaps before answering you should have multiplied 14.4 x 0.7 Sounds like a plan though. I'll release a 20w stereo amplifier and include a 200w fuse. By your math, when I offer it for a $200 you'll shit and buy a truckload.
October 5, 201114 yr Hey everyone I found someone selling this amp on craigslist and wanted to make sure that it is a true 2000 watt amp otherwise I know I'll be getting ripped off.The amp is:2000 watt Performance TekniqueThis one.. with the single 80A fuse recommendation? Its rated at 2000wrms PEAK. That 900wrms rating is most likely inflated too.. youll probably get around 800wrms if youre luckyI agree that the amp doesn't do anywhere near it's advertising.But how do you come to the conclusion that it does 800watts rms?Edit: I see how you calculated that. You did the amp fusing (80a) * 10 and got 800watts? Is this some trick you learned somewhere? I did 80Amps x 14.4volts x .7 for efficiencyAssuming an amplifiers efficiency is well, an assumption. Fuse rating could be on the larger side of things for marketing, or it could be super super inefficient, either way, not a good way for calculating power. Technically a lot more amperage can pass through a fuse rated for xxx.Efficiency changes depending on the material being played, as frequency changes so does the impedance on the output side...I don't have any advice on "finding out if an amp really makes rated power", I guess you could use a dmm, clamp meter, a calculator, and some pen & paper, but why bother? It's always changing...
October 5, 201114 yr Perhaps before answering you should have multiplied 14.4 x 0.7 Sounds like a plan though. I'll release a 20w stereo amplifier and include a 200w fuse. By your math, when I offer it for a $200 you'll shit and buy a truckload.Ugh, I wont even bother arguing with you Although I dont post too much, I read a LOT... and I know that youll prove me wrong hahaAssuming an amplifiers efficiency is well, an assumption. Fuse rating could be on the larger side of things for marketing, or it could be super super inefficient, either way, not a good way for calculating power. Technically a lot more amperage can pass through a fuse rated for xxx.Efficiency changes depending on the material being played, as frequency changes so does the impedance on the output side...I don't have any advice on "finding out if an amp really makes rated power", I guess you could use a dmm, clamp meter, a calculator, and some pen & paper, but why bother? It's always changing...Yeah, thats true. I was just estimating power output. I never said that thats how much power he'd get.. I say "if he was lucky," he'd get that power I completely agree with the bolded.
October 5, 201114 yr Perhaps before answering you should have multiplied 14.4 x 0.7 Sounds like a plan though. I'll release a 20w stereo amplifier and include a 200w fuse. By your math, when I offer it for a $200 you'll shit and buy a truckload.Ugh, I wont even bother arguing with you Although I dont post too much, I read a LOT... and I know that youll prove me wrong hahaBe hard to prove that 14.4 * 0.7 isn't ~10 As for the fusing, my point wasn't to argue but to point out its a useless metric. As EVERY rule of thumb is that you've ever read. Smells like more SMD misinformation to me, although there are a plethora of other places it could have stemmed from.Oh, and you could have argued you'd only pay $175 Lastly, you should post more. Best way to learn is to teach.
October 5, 201114 yr The 2000 watt peak rating is what is known as "ISBL" rating."If Struck By Lighning" = ISBL
October 5, 201114 yr The 2000 watt peak rating is what is known as "ISBL" rating."If Struck By Lighning" = ISBLlmfao!!!
