Posted October 9, 201114 yr i have a vid uploading if yall want to see thatthought it was my battery but my alt isnt charging at all,maybe its my belt because it is the same one the puit on there(had to go to nissan to get this installed)i have the positive from the alt going top my back batteryand the oem 4 gauge going to the front battery.it was charging well for the first day then the 2nd day just crapped out.vid coming soon http://www.youtube.com/watch?v=k0kW3938HTY&feature=player_embedded
October 9, 201114 yr Author got my dad to jump my car, got them dmm out put it on ac voltage, put a prong to the 0 gauge and grounded the negative, it read 27 volts.. any ideas?
October 10, 201114 yr I replied on the other forum. We are here until 6pm EST today and can walk you through testing. From the video I have 2 suspect issues, one is belt slip the other is a loose connection. Make sure the connectors are bottomed out. Even when they feel like they are locked in they may not be fully inserted. Also check your power cables, make sure something didn't come loose!-Eric.
