Posted November 11, 201114 yr Hey everyone, I'd like to know if there is an alternative to changing the color of my headlight without HIDs. I'm not a fan of HIDs because they tend to hurt my eyes when I see people driving so I wouldn't want to do that to others. But what I do want is to not have the stock "yellowish" light and have a different color like blue, white, etc. What's a good alternative that isn't so expensive?
November 11, 201114 yr I currently have HIDs, but I've adjusted the headlight assembly to point more downward to compensate for the somewhat sporadic light, my Toyota has a round/separate housing within the headlight for the low beam and it doesn't shoot off too wild... obviously I'd benefit from retro-fit but kinda expensive...
November 11, 201114 yr You can't change the color much without HID's. If you aim HID's correctly they don't hurt anyones eyes.I currently have HIDs, but I've adjusted the headlight assembly to point more downward to compensate for the somewhat sporadic light, my Toyota has a round/separate housing within the headlight for the low beam and it doesn't shoot off too wild... obviously I'd benefit from retro-fit but kinda expensive...Same here. I have no issues blinding people.My Cutoff is badass.
November 11, 201114 yr You can't change the color much without HID's. If you aim HID's correctly they don't hurt anyones eyes.why you lie!!! PIAA have a blue colored bulb and are almost always higher wattage, so they burn white... Problem with them is you notice lots of flickering during bass notes... LOTS!!!
November 11, 201114 yr You can't change the color much without HID's. If you aim HID's correctly they don't hurt anyones eyes.I currently have HIDs, but I've adjusted the headlight assembly to point more downward to compensate for the somewhat sporadic light, my Toyota has a round/separate housing within the headlight for the low beam and it doesn't shoot off too wild... obviously I'd benefit from retro-fit but kinda expensive...Same here. I have no issues blinding people.My Cutoff is badass.I need to get my battery or better tool to finish the job better... currently left side is higher since I can't get to it...I'm lazy as well.. Your cutoff looks amazing Drew... And your thumb nails too!!!
November 11, 201114 yr You can't change the color much without HID's. If you aim HID's correctly they don't hurt anyones eyes.why you lie!!! PIAA have a blue colored bulb and are almost always higher wattage, so they burn white... Problem with them is you notice lots of flickering during bass notes... LOTS!!!Those things look like a bag of smashed assholes.
November 12, 201114 yr Author Well dang, lol. Would a low wattage HID kit not be blinding to the eye? I just hate stock bulbs! My ranger had a 10k HID kit, but I knew I was disturbing to oncoming traffic lol. Something like 2k?
November 12, 201114 yr Author So if I replaced my stock bulbs with these http://www.shopatron.com/products/productdetail/part_number=PIA10904/353.0 Would it not be yellow? If I just plug and play? Any more I'd have to do?
November 12, 201114 yr wattage doesn't matter... it is the light spray or run-off.... it'll be bothersome either way but just more intense with higher wattage... lol.Look into the PIAA for reals.... they're good
November 12, 201114 yr Author wattage doesn't matter... it is the light spray or run-off.... it'll be bothersome either way but just more intense with higher wattage... lol.Look into the PIAA for reals.... they're goodOh. I thought higher the wattage, the brighter the light lol. I'm Lookin at the piaas, could it be as simple as replacing bulbs?
November 12, 201114 yr Higher is brighter but with HIDs any wattage is bothersome with light run off. PIAA are drop in replacement if you get the correct bulb. Lol
November 12, 201114 yr Author Higher is brighter but with HIDs any wattage is bothersome with light run off. PIAA are drop in replacement if you get the correct bulb. LolSweet. Yeah I'll make sure it's the right bulb lol. I believe mine is H4.... I'd have to look into that lol. So what do you mean the light flickers every bass note?
November 12, 201114 yr Author You can't change the color much without HID's. If you aim HID's correctly they don't hurt anyones eyes.why you lie!!! PIAA have a blue colored bulb and are almost always higher wattage, so they burn white... Problem with them is you notice lots of flickering during bass notes... LOTS!!!Those things look like a bag of smashed arsehos. Why you say that?
November 12, 201114 yr Higher is brighter but with HIDs any wattage is bothersome with light run off. PIAA are drop in replacement if you get the correct bulb. LolSweet. Yeah I'll make sure it's the right bulb lol. I believe mine is H4.... I'd have to look into that lol. So what do you mean the light flickers every bass note?well, without proper electrical halogen bulbs are more sensitive to voltage changes... the PIAAs are more noticeable since they are higher output... REPLACEMENT GUIDE
November 13, 201114 yr I would suggest doing a 4300k HID kit and put a slight tint over the headlights to keep the glare down for oncoming traffic.
November 13, 201114 yr Author I would suggest doing a 4300k HID kit and put a slight tint over the headlights to keep the glare down for oncoming traffic.That's also what some of my friends suggested.. I'm going to experiment.. I'll get the PIAA replacement bulbs and show it here, get some opinions on it and if it's pretty bad, I guess HIDS won't hurt. HIDS will look right after i get a nice body kit done. I just don't have money for repaint just yet
November 13, 201114 yr Author I'll make a build log on my civic, it's gonna be pretty awesome. Performance, audio, body. Etc.
November 13, 201114 yr I'll make a build log on my civic, it's gonna be pretty awesome. Performance, audio, body. Etc.Dont waste the money. Use it for your sound system,
November 13, 201114 yr Author I'll make a build log on my civic, it's gonna be pretty awesome. Performance, audio, body. Etc.Dont waste the money. Use it for your sound system,I got time.. Edited November 13, 201114 yr by Angelboy863
November 13, 201114 yr I'll make a build log on my civic, it's gonna be pretty awesome. Performance, audio, body. Etc.Dont waste the money. Use it for your sound system,I got time..But the money, why waste it?
November 14, 201114 yr Eh, it's not wasting in my opinion. Not looking for a big sound systemBut for the people that have to look at them it is. They dont make you see that much better.
November 14, 201114 yr ya you cant really change the color without going to HIDs... and if you aim them correctly you wont blind anyone...10k = blue4-6k = white
