Posted November 11, 201114 yr http://www.parts-express.com/pe/showdetl.cfm?Partnumber=265-081Could that amplifier reliably produce at least 30w rms per channel run as a sub amp?rated for a 4ohm minimum, but with plenty of reserve i'll be running it at 2ohms.
November 11, 201114 yr http://www.parts-express.com/pe/showdetl.cfm?Partnumber=265-081Could that amplifier reliably produce at least 30w rms per channel run as a sub amp?rated for a 4ohm minimum, but with plenty of reserve i'll be running it at 2ohms.I don't know what type of installation this is, but likely 30watts isn't enough.It's rated for 4ohms, even with enough battery reserve it's still not a good idea to run it at 2ohms.
November 11, 201114 yr http://www.parts-express.com/pe/showdetl.cfm?Partnumber=265-081Could that amplifier reliably produce at least 30w rms per channel run as a sub amp?rated for a 4ohm minimum, but with plenty of reserve i'll be running it at 2ohms.lol... you're always doing something funky speakerboy... lmao..
November 11, 201114 yr Author http://www.parts-express.com/pe/showdetl.cfm?Partnumber=265-081Could that amplifier reliably produce at least 30w rms per channel run as a sub amp?rated for a 4ohm minimum, but with plenty of reserve i'll be running it at 2ohms.lol... you're always doing something funky speakerboy... lmao..shopping around for an amp for the backpack, check my My other thread
