Posted November 13, 201114 yr Would a box that is 2.046 cubes after all displacements with 2 ports that are 1.875x8x22" (will be behind my back seat in my truck) be ok or sound good or give me fair spl numbers with 3 or 4 sa-8s v1 d2s or 3 or 4 orphan 8s in it running off a crescendo bc2000?Is it enough port area? Box volume?Is there anything I should change? Edited November 13, 201114 yr by sps1989
November 13, 201114 yr only because you have it tuned to 40hz is the only reason why i will say it will "work"...Although.. i do not know if you are aware of how it will sound tuned like that though?You want a high tuning like that?You could always back it down to 3 drivers or hell, even 2 and tune lower and keep the same size box.You would lose a little in the high end above 50hz for the "SPL" you mention but for music, i believe it would be more appealing.Of course if you back it down to only 2 drivers, power needs to be attenuated.
February 3, 201214 yr Author I think I may have figured it out. Using 1/8" steel for the ports to save room inside the box. And I forgot to put it on these but the ports are 20.5" long which puts it around 33 hz. Edited February 3, 201214 yr by sps1989
