December 4, 201114 yr I wouldn't see a problem with it, it's most likely made to be in an enclosure and not IB like a car Audio speaker is. It might perform different.
December 4, 201114 yr shielded is just that,,, the motor is shielded so that you can have then close to a tv or a monitor the specs will speak tell the tail on the speaker..
December 4, 201114 yr Author shielded is just that,,, the motor is shielded so that you can have then close to a tv or a monitor the specs will speak tell the tail on the speaker..tanks for the reply
December 4, 201114 yr Author I wouldn't see a problem with it, it's most likely made to be in an enclosure and not IB like a car Audio speaker is. It might perform different.thanks for the reply
