Posted January 3, 201214 yr hey guys should i build this or should i just keep it simple i have no experience designing an 4th order and would hate to waist 2 sheets of mdf if some one has input for a better enclosure lolits going to be a 1:2 chamber ratio rear is going to be 1.28 after displacementsfront is going to be 2.76 cf tuned to 36.09box peaks at 33.79 at 6.69 dband here are pics of what i imagined
January 3, 201214 yr Author Go with a standard ported enclosure with the SA-12!gotcha i have a ported one tuned to 35 hz would the subs do better at a 30 hz vs the 35 that its at?
January 3, 201214 yr All depends on listening tastes! I prefer a 35hz tuning.As far as going with a 4th order bandpass go with a reputable designer. The SA will work great in a bandpass but I personally like a standard 4th order vented enclosure.
January 3, 201214 yr Author gain graphgroup delay highest group dely 33.22hz 52.16msphase plotspl graph
January 4, 201214 yr Author so after reading around alot i have came up with thismy tune was wayy to low so i brought it up to 50 hz also made the sealed chamber 2 and the ported 2.11 tuned to 50 hz here are some pics
